05-08-2022
11:20 PM
05-09-2022
12:37 AM
computergeek541
Hello,
I am not receiving any texts from an android. I own an iphone. Thoughts?
05-09-2022 03:56 AM
My dad had this issue where he wasn't receiving my texts, he is the opposite of tech savvy and sometimes clicks or hits things without knowing it... It was text settings as suggested above and was an easy fix, so hopefully that works for you
05-09-2022 12:31 AM
Also, make sure in your iMessage settings that your phone number/apple ID are both enabled to send/receive texts.
05-08-2022 11:43 PM
@MissGenge Check Messages app settings again.
Go to Settings > Messages > and then make sure that SMS, MMS, iMessage, and Group messaging are turned on.
