Realme 9i
arinasaidulin
Does someone use Realme 9i?
2 REPLIES 2
hairbag1
@arinasaidulin
here's some info on VoLTE and at the bottom you can start process of checking to see if yours is VoLTE recognized...
https://www.publicmobile.ca/en/get-help/articles/volte
slusagm
Realme 9i does not compatible with PM network and I would avoid using it
it has one compatible band on 3G for voice, but PM is phasing that particular band (850) and using another one (1900) which Realme 9i does not have.  So, you will have trouble with voice calls (it is not on PM's VoLTE list so it can't use VoLTE either)
for 4G , it hs only 1 compatible band for data.  With just one band, it pretty much means it won't work most the time
