realme 11 pro plus
davidli
I can not used my realme 11 pro plus
2 REPLIES 2
davidli
I try all this way too but I can only  have data but no volte for calls , seems like all the 3g frequency is out in my area which is downtown Calgary city centre since July  2025 and my realme 11 pro plus 5g 12gb 1tb is a useless brick now that  I used as a music player. now.
@davidli
Start with Reset Network Settings on the phone
If data still does not work, you will have to update the APN manually
Compare the APN settings below, try to update it and save:
APN: SP.MB.COM
Proxy:
Port:
Username: <blank>
Password: <blank>
Server:
MMS Proxy: mmscproxy.mobility.ca
MMS Port: 8799
MCC: 302
MNC: 220
Authentication Type: Not Set
APN Type: default,supl,mms
         or    default,mms,agps,supl,fota,hipri
           (might need to include DUN for hotspot, please note case sensitive)
APN protocol: IPv4
APN roaming protocol: IPv4
APN enable/disable: APN enabled
                or  Turn APN on/off APN turned on
Bearer: Unspecified
MVNO (Mobile virtual network operator) type: GID
MVNO (Mobile virtual network operator)value: 4D      (or try:   4D4F)
