09-11-2024
02:26 PM
09-11-2024
04:16 PM
computergeek541
I've been having issues with the touch sensitivity on my Realme 7 Pro. It seems like I have to press harder than usual, and sometimes the screen doesn't even register my touch properly. Has anyone else experienced this? Are there any fixes or settings I can adjust?
09-11-2024 02:31 PM
Sometime, if you have a screen protector. It will effect the touch screen. Check to see if there is a setting to increase the sensitivity.
09-11-2024 02:29 PM
@Nickbick7788 , you could try doing a factory reset to see if the problem is software related. Other than that, not much in the way of suggestions.
