Add-on amount debited without applying add-on
Edvin12
I tried to purchase an add-on, but the payment was debited and the add-on was not there. So, I had to repurchase it. I need a refund for the first add-on, which was not added to my account.
[update by Softech: Incorrect tagging removed]
2 REPLIES 2
Edvin12
Thank you, i alredy submitted a ticket yesterday and no one contacted me. I'm sending a private message now. Thanks for the reply
hi @Edvin12
it is not normal that they debit you but didn't add you the add-on
but please ask PM support agent to check and help
 submit a ticket with CS Agent using Chatbot here:
             Type the question "Submit ticket", Then click the following in order: "Contact Us" ,  "Other",  "Log In".
If any issue with ticket submission, you can submit  ticket by direct message:
