07-21-2022 01:00 AM - last edited on 07-21-2022 06:20 AM by computergeek541
It's been 6 days and I still don't know what my data usage is yet
07-27-2022 12:18 AM
inappropriate message removed
07-21-2022 02:12 AM
the glitch in the system there is a new design, very soon will be fix it,
you don't worry in here not have extra charge after your limit end is will be off.
07-21-2022 01:42 AM - edited 07-21-2022 02:25 AM
Log in to your account. Your plan usage will be in the middle. Add-on usage will be on the right. Or for your remaining data dial 611 and use your 4 digit account pin and see what you have left.
Adding - or on mobile log in and scroll down a little and you'll see plan usage. Then keep scrolling down and you'll see add-on usage.
As far as detailed real time under View Usage History, not so much. Data always seems to be delayed.
