Reactivate plan
06-27-2019 10:22 AM - edited 01-05-2022 05:36 AM
06-27-2019 12:15 PM
@iliketotalk wrote:@mimmo hi is there an actual button to reactivate a plan once you are suspended? thanks
yes i believe there is when a plan is suspended. i believe it takes you to the payment page. as you typically need to add funds to reactivate a plan. (this is from memory, so i could be mistaken)
06-27-2019 12:00 PM
06-27-2019 11:42 AM - edited 06-27-2019 11:43 AM
06-27-2019 10:45 AM
@Cheycs what have you tried?
by having $200 i am assuming you topped up a couple times. have you tried the lost stolen trick? https://productioncommunity.publicmobile.ca/t5/Paying-for-your-service/SOLUTION-My-plan-has-enough-f...
also assuming you have rebooted phone, and that your plan says expired or suspeneded.
06-27-2019 10:24 AM
@Cheycs a écrit :I now have $200 on my account for a $50 plan nothing I’ve tried has worked
Did you try with the 611? Is your account shows ACTIVE? Can you call or text? Or nothing?
