Re: phones don’t work
Lauchiemackinno
phone calls come through, but we can’t hear the people or they can’t hear us.
@Lauchiemackinno  There’s been an issue with voice for making and receiving calls . Not sure if this is what’s impacting you folks also here’s the link
https://productioncommunity.publicmobile.ca/t5/Announcements/Open-Issue-Service-Impacts/td-p/955119
adding get support to investigate
  • Get support by starting a conversation with virtual Chat box /SIMon. Click here
  • you can send a private message   To CS_Agents by clicking here.
  Watch for reply top of page to the
   Right ( envelope image )
Lauchiemackinno
It’s happening to my wife’s phone as well on the same network not likely the problem. Thank you for the suggestion.
@Lauchiemackinno check if Bluetooth is enabled and connected to a headset.
And see if you click speakerphone, does the voice come
You might want to reboot the phone first, then try Reset All Network and see if it helps
@Lauchiemackinno  Can you try SIM card in another phone and see if services are working correctly also is your volume turned down all the way by any chance
