01-31-2020 06:43 PM - edited 01-05-2022 09:16 AM
I am not able to send pictures via text message. I turned data on and then restarted my phone. I still cannot sent pics with a txt.
I have an iPhone (i think). If I go into Cellular Data Options; Cellular Data Network i see three lines APN isp.mb.com followed by username and password (both blank). Do I need to enter a username and password in order to reconfigure the APN settings as outlined in the thread above. Thank you!
01-31-2020 07:13 PM
@5146 If you have an iPhone no need to mess with APN settings. Just make sure you have enabled MMS within you iMessage settings.
01-31-2020 07:08 PM
If you have an iphone, make sure you have the latest version of ios installed.
Then restart your phone and turn on your mobile data.
01-31-2020 06:56 PM - edited 01-31-2020 06:57 PM
@5146 wrote:I am not able to send pictures via text message. I turned data on and then restarted my phone. I still cannot sent pics with a txt.
@5146 Try this:
Settings > Cellular > Cellular Data Options > Cellular Network
OR
Settings > Mobile Data > Mobile Data Options > Mobile Data Network.
Add a new APN and enter the Public Mobile details -->https://apn-canada.gishan.net/en/apn/public-mobile
APN: sp.mb.com
Proxy: Leave blank
Port: Leave blank
Username: Leave blank
Password: Leave blank
Server: Leave blank
MMSC proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
APN protocol: IPv4
APN roaming protocol: IPv4
Bearer: Unspecified
MVNO type: GID
