Re: can't get incoming calls. Thanks
Shahzadvet
Bought new SIM card and new number but no incoming calls. Can text and can call but no incoming calls
Summersideguy
I've also seen if you Log into your web portal go to plans and add ons.
Click on lost or stolen phone.  Wait five minutes and then click on found and that possible could resolve the issue.  I've seen other post suggest that.
A few things to try....reboot phone. Remove SIM wait 10 min. reinsert and power up. Check phone settings. Block calls? Do not disturb? Another setting? Is it an IPhone? Disable ITunes?
popping
@Shahzadvet wrote:
It’s new number not transfering from any other network. Tried in different phone but still no incoming. Can text send and receive
Restart your phone after changing provider may get your phone working with the new provider.
Shahzadvet
geopublic
@Shahzadvet  Make sure your phone is not on do not disturb mode.
Edited by computergeek541: removed personal information
popping
@Shahzadvet
Please delete your phone number from your post if you don't want any spam calls as this is an open forum.  Any one can read the content of your post.
Did you just port your number to PM?
Number porting is a 2 stage process:
Stage 1. PM set up your old number on your PM account. Login to your account. Select the [Plan and Add-Ons] tab. Is your old number showing on the [Plan and Add-Ons] display?
If yes, PM has done its work to setup your old number for you to call out, send text and data.
Stage 2. Now, you are waiting for your old provider to release you number to PM. Not until your old provider release your number, all the incoming calls and texts will continue to go to your old provider.
