09-07-2025
03:06 PM
09-07-2025
03:16 PM
computergeek541
09-07-2025 03:14 PM
Call 1-855-4PUBLIC to check on the status of your account. If it indicates your account is suspended. You will need to make a manual payment to restore service.
If the system indicates that your number can’t be located then your number has be returned to the carrier your originally got the number from and your account is closed, SIM no longer work because of nonpayment for longer than 90 days. You need to contact the carrier to retrieve your number.
09-07-2025 03:09 PM
hi @75Justin
depends on the situation
if your account just suspended, login My Account and make a payment
if the account was closed, you will need to check with PM support agent. you can submit by direct message:
