11-27-2021 06:24 PM - edited 01-04-2022 05:07 AM
I purchased the US roaming package yesterday from home in Canada. Today, I am in the US and do not have the package. Chatting with Simon did nothing. I tried to contact CS but the preprogrammed responses don't help. How do I activate the package I purchased?
11-27-2021 07:01 PM
@Peewee1947 : Turning on roaming is only for data. You seemed to be saying you had nothing. Glad it's working now.
11-27-2021 06:53 PM
Bingo!!! I didn't know I had to activate roaming on my cell. It appears to have worked. Thanks for your help. Also, thanks to everyone else who contributed suggestions. Cheers.
11-27-2021 06:25 PM - edited 11-27-2021 06:27 PM
Check your account. Do you you see the add-on ? If not, do you still see a balance in your account ? If you have a balance then you need to buy the add-on by adding it to your account.
Also make sure to enable roaming on your phone.
https://www.publicmobile.ca/en/on/get-help/articles/us-roaming
