09-23-2021 07:32 PM - edited 01-06-2022 03:37 AM
There should be a number to call when porting number. Its just frustrating nobody reply with the trouble ticket to simon chatbot.
10-03-2021 06:11 PM
@de26 : You haven't finished with this yet? Someone has likely sent you the number. I edited it out of my post because it's sorta not supposed to be shown here although I think that's a dumb policy. So click on the little envelope in the upper right by your coffee cup avatar and then click on the subject line to open a message.
10-03-2021 05:59 PM
@de26 do you have issue with porting your number into PM? That number is for Telus Porting team to get porting status and re-trigger porting request
10-03-2021 05:57 PM
whats the number?
09-30-2021 01:00 PM
@de26 wrote:There should be a number to call when porting number. Its just frustrating nobody reply with the trouble ticket to simon chatbot.
What kind of porting issue(s) you are facing?
Does SMS works?
09-30-2021 12:47 PM
if you stuck with Transferring your old Phone Number,
Here’s how to contact Customer Support Agent by CS_Agent,
Good Luck...
09-29-2021 08:33 PM
Did you leave your old SIM in the phone and wait for a SMS text from your previous carrier that you are porting over to PM with a YES? Once you get the text, you have 90 minutes window to confirm.
If you missed this step, only a PM CS Agent can help you to complete your porting.
09-29-2021 04:08 PM
The telus porting department can only help with certain issues with porting only. If you tell us your problem we can ensure you are headed in the right direction. Do you have an issue with porting your number to public mobile?
09-29-2021 04:04 PM - edited 10-03-2021 02:26 PM
This was the Telus porting help line. Thank you Luddite.
09-29-2021 04:04 PM
09-29-2021 04:01 PM
I mean the technical port people.
09-29-2021 03:56 PM
@de26 : Not sure what exactly you're asking. Can we help you with whatever problem you might be having?
09-29-2021 03:44 PM
i hope you give me number to call
09-24-2021 08:29 AM
There is none. I hope there is.
09-24-2021 08:15 AM
Do you have porting issue?
there is in fact a number to contact to confirm porting status. People who missed the text from the old provider can call the porting team to re-trigger the SMS process.
