Re: Network upgrade
diggerleem
I was recently told my brand new iPhone isn't compatible according to its IMEI. Is that likely an error?
18 REPLIES 18
diggerleem
Now working, unclear what changed to make it successful. But thanks a lot for everyone's assistance!
@diggerleem
Please give Public Mobile another chance for to confirm what went wrong.  I have escalated your request for another review and agent will contact you again
diggerleem
They won't say why it is not compatible only to switch to a compatible device (if not the latest iPhone then not sure what).
It is a brand new Canadian iPhone ordered from Canadian Apple.com website.
hi @diggerleem
what did CSM_PM say? why an iPhone does not work here? did you buy in Canada? or overseas?
diggerleem
Sadly it seems that the answer is that my device is not compatible despite being brand new 😞
CSA_PM
Customer Support Agent
We appreciate your escalation. An agent is already assisting the customer and will ensure they receive the support they need.
CSA_PM
diggerleem
Confirmed! Both IMEI and IMEI2 numbers showing success on device check
hi @diggerleem
confirm if your phone is clean.  it should have 2 IMEI, please check both
https://www.devicecheck.ca/check-status-device-canada/
diggerleem
I have a brand new iPhone 17 Pro Max which is eSIM only not compatible with the PM network due to its IMEI number. When I try to buy a plan I am stuck in pre-activation and it fails with an unclear error message in the app. Using a web browser, I get a more descriptive error message M.8702 that my payment was successful but the plan cannot be created.
None of the error messages mention the IMEI number is an issue, using the checker it says I am compatible according to the IMEI number. But regardless support will not budge on this issue and say I need to get a compatible device to use PM.
Is the iPhone 17 really not compatible with the PM network? Any way I can move forward here.
diggerleem
I also have this issue and it is unresolved.
diggerleem
It is an iPhone 17 Pro Max
diggerleem
Unfortunately they are not letting me open another ticket and saying this:
"The IMEI can't be changed for our website. Please change to a compatible device or please try to switch to Koodo/TELUS if your device is compatible with them
Best regards,
Maria, CS Agent"
diggerleem
Unfortunately they are holding their ground and telling me that I cannot open another ticket with the same problem. It is a brand new iPhone and IMEI is not in the database. I do not know if it could be due to my postal code in Newfoundland.
Yummy
WHO told you that???
If you are checking IMEI at PM site be aware that their public database is NOT correct. To be 100% sure talk to agent and let them check against their internal database.
hi @diggerleem
no worries, all new iPhones are compatible.    you can talk to PM agent and make sure they have your account marked with the correct device and won't charge you the $5 legacy network fees.
submit a ticket with CS Agent using Chatbot here:
             Type the question "Ticket", Then click the following in order: "Account Management" , "Log In".
             (If unable to receive 2FA SMS, click "Didn't Receive Code" or "Resend Code" and Select "Send Email")
If any issue with ticket submission, you can submit  ticket by direct message:
