06-28-2017 08:29 PM - edited 01-04-2022 02:14 PM
06-28-2017 09:05 PM
The process is quite easy
1) order a sim card (delevery only in canada)
2) activate the card when you want to start using it
3) do not enable autopay
4) delete the creditcard on file
5) after 30 days the plan expires and after 90 days the acocunt is deleted.
06-28-2017 08:45 PM
@nenaluchuy As @Luddite mentioned for all simple questions please don't involve the mods. The community is here to help you out with simple questions.
For all account related matters, you can feel free to contact a mod.
Thanks.
06-28-2017 08:33 PM
@nenaluchuy No need for a moderator. When creating your account do not turn on autopay. Once you establish service is functioning, login to your account and DELETE the credit card info. 90 days after the expiry of your plan, the account will be deleted.
