Re: How plans work at Public Mobile?
Caeser
Hi i have a plan i pay every 3 months is it possible to use my plan for my desk top as well as my cell.Just wondering as i'm paying 2 different providers and not using anything close to a small portion of each plan.Just wondering appreciate any response thank you.
imm1304
Hi @Kerri!
The hotspot feature is enabled by default and it should work for you.
If you experience trouble with it, let us know and we will try and help you with modifying your phone's apn settings to get it working.
Kerri
Isn't it necessary to ativate the hot spot feature with public Mobile?
will13am
@Caeser, the occasional tethering session to a computer works great with these data rich 90 day plans.  As mentioned already, these don't replace data only plans.  I have a data only plan to supplement my cell plan.  I am not going to shill various data plan options here.  You can google it yourself, try key words 3 GB, free.
mimmo
@Caeser you could hotspot you phone. And use that hotspot to connect you computer.  Just beware your comp could easily est though your data doing updates.
Unless you have a grandfathered plan it is ptobsbly best to find an inmarket one that is closer to your actual usage.
