10-27-2016 03:05 PM - edited 01-04-2022 03:45 PM
10-27-2016 03:37 PM
@WearySky wrote:@neilselden the thing is, PM sent them by mistake, so @owyajoe shouldn't be on the hook to pay to return them. And making PM pay to return them just doubles the cost of sending them out. I'd definitely go with "pass them along to a new referral" as the best win-win situation for everybody involved (PM, @owyajoe, and whomever they refer).
@WearySky legally you are NEVER required to return something sent to you. Now most of us are good people and all so if you found a box from Amazon or something would probably send back.
You are not even required to advise the shipper that you did receive the item.
Please note this is TOTALLY different than receiving someone else's mailed package. The keep it rule ONLY applies if it is addressed to you.
10-27-2016 03:33 PM
I'd like to think Public gave them to you to refer others ![]()
Either way they never expire so worst case scenario you can use them as needed
I am doubtful Public would accept them as a return
10-27-2016 03:18 PM
10-27-2016 03:16 PM
10-27-2016 03:14 PM
Definitely refer refer refer!
10-27-2016 03:08 PM
Hi,
DIfficult moral dilemna......
If you did not pay for them, you may want to return them.
OR...... convert two other people to Public Mobile and give the SIMS away. This may be the best option: Public Mobile gets two more subscribers, and you get $2 off per month 😉
Cheers,
Neil
10-27-2016 03:07 PM
hi...
please contact one of the PM moderators and ask them what to do with it....
personally i would keep them i case you have friends or other family members who would like to join PM and you can add them as "referals" ...you will collect 1/month for each line you refer.....
cheers
10-27-2016 03:07 PM
You could use them for when you refer others... Save them $5 in the process.
