07-11-2023 01:00 PM
I purchased a USA roaming add on before I travelled across the boarder. One there, my phone was showing Tmobile and had roaming turned on, started and restarted my phone, on and off airplane mode etc. No luck, roaming didn't connect. I want a REFUND!!!!!!!
07-11-2023 05:10 PM
In your phone setting , you need turn "enable roaming" ON.
07-11-2023 01:09 PM
Yes, you can try to open ticket with PM and see if they can compensate:
If your issue is with data, make sure your Roaming Mobile data is enabled and your have disabled your mobile data limter
If your issue is with voice, make sure VoLTE is enabled on the device setting. And if it does not work, try to change the Preferred Network Type or Network Mode to 2G and see if the calls goes through
Also, you can download VoIP app TextNow as a workaround to make calls and text if you have Wifi or if your roaming has data component and data is working
07-11-2023 01:01 PM
@nononickname You need to engage support for that
message support directly
while your already here and logged in the community you can send a private message To CS_Agents click
VVVVV Link below VVVVV
