RE: Account - xxxxxxx
03-24-2020 02:51 PM - edited 01-05-2022 10:04 AM
I am locked out of my account. I have sent the moderators a message regarding this issue. Please address it as soon as possible.
edit by mimmo removed personal info
Joining Public
03-24-2020 03:16 PM
After submitted a ticket, members should check their private message SENT folder for their ticket which they just created.
If you cannot find your ticket in your SENT box, You did not create your support ticket yet. Also monitor your INBOX for any reply from moderator.
Click the envelop icon at the top right corner to access your private message mailbox.
You can also enable email notification after you receiving a private message at your INBOX
My settings --> PREFERENCES --> Private Messenger --> enable "Receive email notifications for new private messages' --> Save
03-24-2020 03:00 PM - edited 03-24-2020 03:01 PM
@sthareja24 in the meantime, if know your self service accounts email sign in, password and the answer to your secret question. You can try to get in again. Wait 50 minutes from last attempt, clear your browser history, go to private/ incognito mode and try again to login. If this fails, you can try the password reset link once you know the answer to your secret question. Good luck.
Keep an eye on the envelope top right of your screen. The mods answer will show up there.
03-24-2020 03:00 PM
@sthareja24 Just be patient. Mods have high load now for sure, but they get back to you within up to 72 hours. Don't worry.
03-24-2020 02:53 PM
@sthareja24 if you have messaged the mods that is the only way to get support. you will just need to wait till they respond.
if you need to make a payment try buying a voucher and using 611 to apply the voucher.
03-24-2020 02:52 PM - edited 03-24-2020 02:54 PM
If you sent them message, stay put they will respond within 48 hours, hopefully much much sooner.
Look out for the little envelope on the upper right corner, that's where response will come.
You will have to do authentication and let them know when it's completed, that step will be very important
In a meantime you can use voucher and 611 if you need to keep your service going
Best luck
