09-01-2025
11:45 PM
09-02-2025
12:52 PM
computergeek541
Looking for help please.
2 weeks ago
It’s happening to me again today, anyone else?
09-03-2025 07:53 PM
Thank you. Ticket created.
09-02-2025 07:16 PM
hi @LaneDriver
try Reset Network Settings and make sure your Carrier Profile is updated
If same, please submit a ticket with CS Agent using this Chatbot link: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit by direct message:
09-02-2025 07:14 PM
@LaneDriver it depends if you can receive regular SMS and calls
I have escalated your ticket on behalf. PM support will reach out to your via Community inbox. Please monitor here for their reply:
09-02-2025 07:02 PM
Thank you for the reply. Unfortunately, this was not successful. Also wouldn’t the fact that the phone cannot send SMS messages suggest this may be a broader issue than iMessage?
09-01-2025 11:48 PM - edited 09-01-2025 11:48 PM
@LaneDriver your issue is iMessage not activated yet after the porting
Manually remove the phone number from Settings, Reboot phone, then go back Settings and reenter the phone number to force a re-registration. Please note that it might take time, please wait. If it takes too long and still unable to re-register, wait couple hours and try again with the same steps above
