09-23-2025 03:51 PM - edited 09-24-2025 07:25 AM
PM has implemented some fixes on their end. They have sent out a SMS to people outlining the fix needed on our end. In app turn off RCS. Go into app info clear data AND cache, force stop, reboot phone. Open messaging app and turn on RCS. It worked immediately for me. This was the issue I submitted to them yesterday and they were very quick (within 30 mins each time) to reply. This SMS just came out.
Provided by @on2wheels, On iOS the instructions were to disable RCS, reset networks, the phone will restart and then you need to reenable RCS.
09-26-2025 05:18 PM
Found it. Thx so much.
09-26-2025 05:13 PM
You said “go into app info” where do I find that on my IPhone? Thx
09-26-2025 10:45 AM
Many thanks for this. I’ve been looking into this on iOS for several days and this solved the issue!! Cheers!
09-24-2025 07:25 AM
@on2wheels Done
09-23-2025 05:13 PM
@on2wheels wrote:On iOS the instructions were to disable RCS, reset networks, the phone will restart and reenable RCS. This worked for me, it is now working. @kb_mv can you add that to your post so it doesn't get lost?
I can confirm it’s working on my iPhone also. Except I wanted my eSIM back (installed a SIM Card the other day to replace my eSIM due to I was told it may fix RCS which didn’t) so I purchased an eSIM after making sure RCS toggle was off in message section, rebooted iPhone, checked IMS Section & it showed “Voice, SMS & RCS” finally, then I checked the message section to toggle it on but it was automatically turned on! I sent a test message to another phone & it successfully sent, was received & also received response back through RCS! 👏🏻
09-23-2025 05:06 PM
Works for me on iOS, thanks!
09-23-2025 04:53 PM - edited 09-23-2025 05:27 PM
On iOS the instructions were to disable RCS, reset networks, the phone will restart and then you need to reenable RCS. This worked for me, it is now working, thankyou PM admins. @kb_mv can you add that to your post so it doesn't get lost?
09-23-2025 03:52 PM
thanks @kb_mv
