09-26-2025
02:34 PM
09-26-2025
09:11 PM
computergeek541
I use PM and when someone calls me, it goes straight to my voicemail. Unless they call twice in a row quickly. If they call twice in a row quickly I can get a call. It is important because if someone important calls me they call once and they just leave a message and this is not effective.
09-26-2025 05:23 PM
Nvm I got the phone working properly by resetting network settings. Thanks a bunch.
09-26-2025 05:07 PM
I checked both IMEI numbers on my phone and they are not compatible. I started having this issue 3-5 days ago and it wasn't there before. What can be done in this situation now?
09-26-2025 02:37 PM
What phone do you have?
Check if you phone is on PM's VoLTE whitelist as that could be the reason
https://www.publicmobile.ca/en/on/get-help/articles/volte
Also, try reboot, and Reset Network Settings
