11-23-2022
09:45 AM
11-23-2022
03:35 PM
computergeek541
11-23-2022 12:37 PM
Did you set up the plan change to happen on the next renewal? Or did you change it immediately and paid for it at that moment?
Check your payment history here to follow the cash flow of payments and charges and rewards.
Immediate plan change does not put in the rewards. Scheduled plan change does.
11-23-2022 12:31 PM
Thanks for you answer....but I did the change 2 week ago .
11-23-2022 12:30 PM
Ok thanks for you answer ....I understand what you say about rewards......but idid the change 2 week ago.
11-23-2022 12:27 PM
Ok thanks .....but idid the change 2 weekend ago , doesnt show
11-23-2022 10:01 AM
HI @juanluis you will get to keep the same rewards after plan change.
the only thing is , try to use Change on renewal date instead of Change plan now.
For Change plan now, you "wasted" the unused date on the current cycle and PM will charge you full price for this one mid-cycle plan change
11-23-2022 09:48 AM
Could you clarify your question, please.
Your rewards will stay as is. They are tied up with Account not plan.
If you did not change plan then charge will sty the same you were paying before.
If you changed plan then higher amount will be charged (after rewards credit) if your previous plan was cheaper.
11-23-2022 09:46 AM
@juanluis If you switch to the new plan right away, rewards don't get applied this time around.
