Question re: US Roam-Talk Txt 3 GB Data(15d)
rooster
Good day everyone,
Asking this question because I've heard different things and looking for clarification.
If I buy the "US Roam-Talk Txt 3 GB Data(15d)",
then I use all the 3gb data.
Can I buy the 25$ 15-day 3gb USA addon ?
Can I rinse and repeat this ?
Or do I have to wait until the 15 days period is over, then purchase?
thanks
2 REPLIES 2
@rooster  - if you run out of data, and you want the same roaming addon to your account before the 360 hours, you can contact customer support to get that added to your account for you by submitting a ticket to them. Annoying to do so, but that is how it is for now. 😕
Or, buy a totally different 'data bucket', then you won't get stuck in that issue.
hairbag1
@rooster
You can use it for 360 hours + 24 hours ...then rebuy the same add-on.
edited...
but once you've used all the 3g data...you can buy any one of the 3 Roaming Data options avaialble.
