02-02-2026 07:35 PM
How do I cancel my public mobile account and phone number? I no longer am needing my phone number and account. Any information would be great! I can not seem to find any info to do so.
02-02-2026 08:59 PM
Just to clarify, when you disable Subscribe. It will stop your AutoPay to pay for your monthly payment. After 90 days of nonpayment, your account will be closed, your SIM will stop working and your number will be returned to the carrier you got the number from.
02-02-2026 07:49 PM
hi @Cindyhair
it will suspend your account at the end of this cycle. Then 90 more days, your account would be closed
but if you like to cancel it immediately, message PM, use the link above
02-02-2026 07:44 PM
I see I can unsubscribe does that cancel my service right away? Also I want to cancel the phone number but is says it will cancel it in 90 days. I need it to not be in service asap.
02-02-2026 07:37 PM
if you can login My Account, disable autopay yourself. Go to Payment -> Manage Subscription and turn off subscrxibed
if you cannot login to do that, ask PM to help. Since you cannot properly login, you won't be able to open the preferred Chatbot ticket. So, you will need to message them here:
