04-24-2019 11:08 PM - edited 01-05-2022 07:18 AM
Do all public mobile numbers start with area code 289?
04-25-2019 12:01 AM - edited 04-25-2019 12:02 AM
@clinton97 wrote:Do all public mobile numbers start with area code 289?
No. Public Mobile has phone numbers available in many area codes. In this case, 289 is used in "905 areas" in Ontario. Many area codes also cover mulitple cities. What citiy are you looking for?
04-24-2019 11:40 PM
There are always more and more area codes in Canada:
So... gone are the days when I could tell "That area code is for this or that city !
Source: https://www.areacodehelp.com/canada/canada_area_codes.shtml
04-24-2019 11:21 PM
Area codes are different across the country. Certain area codes may not have a large selection as all carriers are given a group of n7mbers to distribute.
04-24-2019 11:19 PM - edited 04-24-2019 11:34 PM
No, you can choose an area code from your area / covering your town. It's likely that it will be a newer one for most regions as the traditional area code numbers are all being allocated.
For example if you are in Vancouver getting a new 604 number is essentially impossible, for 778 there might or might not be new numbers availble, so you likely get 236 number or even have the choice for a 672 number. If you are in Powell River? Plenty of 604 numbers available...
http://www.cnac.ca/co_codes/co_code_status.htm
Looks like 289 is one of three (365 and 905 being the others) covering the same area
04-24-2019 11:14 PM
no, I just ported my (613) number to PM, so mine doesn't. I don't think I am the only PM user who has an area code other than 289...
