international texting
dukes
Is it free to text from Canada to New Zealand or what is the best way,thanks all
Usually yes, but not necessarily.  Not all plans that Public Mobile customers have included outgoing text messages to anywhere.  While the current ones do (except data only plan), there have been past plans that do not.
dukes
thank you
hairbag1
You can send to and recieve from anywhere in the world....as long as you're in Canada. Once you leave Canada you need to consider other options.
Welcome to Public Mobile
Triguy
Yes, international texts are included in all plans except the 1GB data only plan,
