02-09-2023
12:50 AM
02-09-2023
05:15 AM
computergeek541
Hi I just made a blunder and ordered a Xiaomi phone from China which is the Global ROM instead of Global Verison.
The phone is Xiaomi Note 12 Pro which has basically none of the bands of public except only 1. Which is B5 or 850mhz. Will my phone work (calling, text and data) if I only have 1 band?
If it will work. Will call quality be bad or will it only work in 850mhz locations near those towers or will it work everywhere?
And if it doesn't then man i'm screwed. I can't return the phone and I have learned a valuable lesson to check the phone bands before buying.
Thank you for any information.
02-09-2023 08:44 AM
Thank you but, what you posted is exactly what I know already... I already know it works with B5.
02-09-2023 08:43 AM
Thank you for your informative response. I didn't know it requires 2 bands looks like i'm screwed. But thanks for the suggestion to sell it. Maybe i can recoup some with that.
02-09-2023 06:13 AM
02-09-2023 06:00 AM - edited 02-09-2023 06:19 AM
@hobokingdom Xiaomi Redmi Note 12 Pro
these are the bands on your phone, BOLD are compatible bands with PM
3G bands HSDPA 800 / 850 / 900 / 2100
4G bands 1, 3, 5, 8, 19, 34, 38, 39, 40, 41 - International, China
Basically, I would not recommend this phone to use on PM network
Your voice will not be working well as PM uses 2 bands for voices and you are missing half of it
For LTE connection , it would be poor as it has only one of the many bands PM uses
You have other it and cannot return it, so, just try it or sell it to others who are on a different network
02-09-2023 01:09 AM
It even looks a little light on the 4G side for here. One. Sucks. I think that phone would be a challenge for here.
02-09-2023 12:53 AM
