Put wrong package on phone
LandATownsend
I put  $15 US plan on phone (this morning) for $15, but I don't need text I need phone calls. Can I get it cancelled so I can pick the phone call option?
@LandATownsend
If are just looking for a calling plan. You can use WhatsApp or TextNow app for free calling and texting through wifi.
You can get a $15 credit into your account by a CS_Agent for the wrong purchase.
Chalupa_Batman
Hello @LandATownsend
I can tell you that all plans with Public Mobile come with texting. Unlimited U.S. Talk and Text Bundle $15 is the cheapest bundle you can get for US roaming. So you DID get the correct addon.
hairbag1
@LandATownsend
that $15 US 15 Day Roaming add-on includes talk and text. You must have a volte enabled cellphone that's on the PM whitelist of volte enabled phones to be able to use it in US. Go in to the settings to make sure volte is turned on.
@LandATownsend  Support team should be able to help reverse it for you
send  a  private message   To CS_Agent
⬇️⬇️⬇️⬇️⬇️Link below ⬇️⬇️⬇️⬇️⬇️
