Purchased wrong add on
ACGB
I seem to have accidentally purchased a 1GB data add on for the US instead of just a normal 1GB for Canada. However, I’m not in the US. Is there any way to exchange/cancel it?
2 REPLIES 2
@ACGB PM is a prepaid provider and usually does not provide refund.  But generally, they will help in situation like this
Please open ticket with PM support:
1. Open ticket via Chatbot (need access to My Account): At https://widget.telus.tiia.ai/publicmobile/publicmobile.html
    Start by typing "Submit a ticket", then click "Contact Us", then "Other", then "Log In", finally click "Click here to submit a ticket ↗
HALIMACS
Yes @ACGB , but you'll need customer support to do this
  1. Use the ticketing system by clicking here , then Contact Us,  or
  2. Send a private message to Customer Support Agent by clicking here.  You’ll need to be logged into your Community account for the link to work.
