09-17-2023 10:01 AM
09-17-2023 10:08 AM
But does it WORK @Dataless ?
You may not 'see' it displaying on your account, however it may still be in effect.
09-17-2023 10:06 AM
@Dataless First
Try again incognito/private mode
And or lap top /computer
OR
simply try refreshing the page to check data plan / mins / add ons
09-17-2023 10:04 AM
Hi @Dataless
If you log onto your account, click on subscriptions and addons, you will see a spinning wheel. Click on that to update under Addons on the right side.
09-17-2023 10:04 AM
Roaming data or Canada data? Click on all the little spinner refresh icons you see lower down to make sure you're seeing current info.
