04-16-2025 11:28 AM
Purchased add on data, and it shows in dashboard, but cannot access data on phone
04-16-2025 12:25 PM
04-16-2025 11:51 AM
@Renee10 wrote:Yep. Tried that. Thanks though!
As @Phil_Adelphus mentioned, are you 100% sure you purchase a Canadian data addon and not accidently purchased a US data addon?
If you did purchase a Canadian data addon and it's still not working after a network refresh or a reboot, the create a ticket and request a CS Agent to investigate why.
Please use this link to the Public Mobile Chat Bot which will direct you to creating a trackable ticket.
04-16-2025 11:35 AM
04-16-2025 11:34 AM
@Renee10 Check to make sure you got the right data add on, i.e. whether it's for US roaming or use in Canada. The US one will have a limit of 15 days and the Canadian one is 30 days.
04-16-2025 11:31 AM - edited 04-16-2025 11:36 AM
Just reboot your phone by powering off then back on. See if that works.
If not, reset the network settings.
04-16-2025 11:29 AM
@Renee10 wrote:Purchased add on data, and it shows in dashboard, but cannot access data on phone
Have you tried to reboot your phone? I know it sounds silly but....
