Purchased add on by mistake does anyone knows if i can cancel the add on data whitin 24hr
Aellll21
Aellll21
Yay thank you!
Your welcome . You should get a response from support with in the hour . They will ask you some verification questions first before they are able to help you . Hope you get  a quick reply and speedy resolve
Aellll21
I've submited the ticket thanks bud!
@Aellll21  If you just did this by accident . Please submit ticket with support . And ask them if they can reverse this for you . Use this direct link to support
send a  private message   To CS_Agents click
