Puk code
dennis77fox
My sim is locked after a reset, says I need a PUK code
RossN
@dennis77fox
if it is the SIM card puk you are looking for ,  you can open ticket with this direct link :
https://urlshortner.tiia.ai/Oyn1L6
DDM69
You'll need to submit a ticket with a moderator.
DDM69
Search puk code in the search bar.  This should help...or
Youu need to open a ticket with Mod to get the PUK unlock code
(After you open a ticket with mod, please monitor your Community inbox, envelope on the top right.  Mod will communicate with you via messaging within Community)
1. For faster response (2 to 48 hours), Click on the bubble in the lower right corner and request moderator assistance, or you can also use this direct link instead https://publicmobile.ca/chatbot , then type "Submit a ticket", select Account-specific issue, then select I need a human now. Follow the prompts to submit a ticket.
2. Or you can Send a private message to the moderator here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
