05-19-2023 02:20 PM
Hello I have lost access to self serve because I can’t remember the email password. I used when I created my account with Public Mobile. I also made a new email to be the security and forgot that password as well. I want to use my new email for public mobile self serve, how can I change this? I have never been able to sign in to me self serve since I got the phone 2 yrs ago, please help
05-19-2023 05:11 PM
In the future...you need to write all of this down or save it on your phone. Email address, passwords and any other login information or this will continue to be a problem for you. This is all important, so you can monitor your account or make necessary changes.
Good luck.
05-19-2023 03:43 PM
I hope you remember your security PIN because a CS_Agent will need this too to confirm you are you.
05-19-2023 02:21 PM
Only PM support can help with changing email addressed used on My Account login, please open ticket with them:
1. Open ticket with Chatbot for faster response (2-48 hours), using direct link: https://publicmobile.ca/chatbot
First type "Change my Self-serve email", then click "Contact Us", then click "Click here to submit a ticket ↗ "
Next, enter your Community login, click "Next" at "1. Select an issue category", then follow the steps to complete the ticket submission.
2. If you have trouble with Chatbot or you don't have access to My Account: Private message CS Agent at:
