10-15-2025
12:20 AM
10-15-2025
01:57 AM
computergeek541
Hi, I received a text from Public Mobile stating that I have used 95% of my data, but when I checked my usage I am nowhere near.
Anyone experienced something like this?
Thanks!
10-15-2025 06:18 PM
Received the same warning two days ago, shortly followed by a marketing push for a data plan upgrade. Both my phone and customer portal say I only used ~60MB out of 1GB in the last 30 days. Either sent in error or something is messed up with whatever code PM is using to check for usage.
In a different thread, some people have reported their 4G data getting suspended after receiving these seemingly erroneous warnings. Depending on your luck, these spurious warnings may not be benign.
10-15-2025 09:22 AM
Same here.
10-15-2025 01:11 AM
Thank you, much appreciated.
10-15-2025 12:33 AM
thats an acknowledged glitch that Public Mobile is working to fix. Just ignore.
10-15-2025 12:33 AM
Yes, a lot of users have been receiving this incorrect message for a few days now from Public Mobile.
They are aware of it and are working on a fix.
If it doesn't apply to you, you can ignore the message.
