CS_Agent
SJH
The phone number listed for my account isn't correct. I have no usage information and your system wants to send 2nd step authorization to the wrong number.
Would like some help with this and having a REAL PERSON to talk to would be helpful and save me a considerable amount of time.
A phone service you can't call. Cute
2 REPLIES 2
Socrates8567
Hello
If you click on didn't get code, you can send it to your voicemail or email address. once done and you get the code, you can go here to fix it and change the number.
https://eversafe.id.telus.com/user/selfservemenu
If you still need help, contact csa here
slusagm
did you change your phone number lately?
if you click Didn't Receive Code, do you see Send email there? you can use it to get the code and login and change the phone number back at Profile -> Manage EverSafe ID
if you cannot login , ask PM  to help
message PM using this link:
PM will reply to your community inbox,  between 9AM-10PM EST (Mon-Sun), check here:
