08-11-2019 07:16 AM - edited 01-05-2022 08:32 AM
Hi,
I am planning to give my PM sim card to one of my family member who study in Halifax, she wants to keep the Ontario number. The plan is the $25 unlimited Canada wide talk and text plus 1GB data. How is the connection over in Halifax and is it ok to keep the Ontario number? TIA
08-11-2019 08:33 PM
In Nova Scotia, it would be easier to point out where Public Mobile does not work, the Bell/Telus network here is pretty robust.
08-11-2019 08:06 PM
Thanks to those who replied, family member went back to Halifax today and told me she has no problem. Thanks again.
08-11-2019 08:46 AM
You can check coverage map https://publicmobile.ca/coverage
Public Mobile is own by Telus. Same coverage as Telus.
08-11-2019 08:40 AM - edited 08-11-2019 08:49 AM
@apvmIt will work just fine. Just make sure you give her your email and Public Mobile account password and it is probably a good idea to walk her through how the payment system works. That way she can do pretty much everything including changing her number to a Halifax one if she ever needs to.
08-11-2019 08:21 AM
There is good coverage as PM uses Bell & Telus towers.
08-11-2019 08:11 AM
@apvm since it's a Canada wide talk plan, she can keep the number.
Coverage should be very good because she would be using Bell's towers in Halifax.
08-11-2019 07:42 AM
A-okay to keep the number, and with the unlimited nationwide calling in that plan, your family member is covered.
08-11-2019 07:20 AM
I spent a couple of weeks in Halifax/Dartmouth in June. PM was consistently available and I had no issues. As for the number, I have heard lots of people keeping their numbers and moving provinces. No issues there, I believe.
