Public Mobile Number Not Fully Activated
Neofirst
@CS_Agent I recently switched my carrier to Public Mobile, but my number does not seem to be fully activated.
1 REPLY 1
slusagm
what phone do you have ?
Is your old provider sim still working?
Can you make calls? Can you receive calls
Have you open ticket with PM yet?   Since you cannot properly login, you won't be able to open the preferred Chatbot ticket. So, you will need to message them here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
https://productioncommunity.publicmobile.ca/t5/notes/privatenote
