Public Mobile Disconnected LTE
KingofAwsome
Hello,
I received a pop up message on my phone saying Public Mobile Disconnected LTE. Why is this? Should I be concerned?
King
Wellersbayview
My 'solution' (after a few hours of the annoying message but still having service) was to power-down/up my phone. Everything back to normal. iPhone here so it may have been related to the iOS update this week or maybe Telus was doing maintenance.
Keithm0000
I got the pop up too, nothing worked immediately after but I’m able to use data still, so I’m happy about that. However when I make phone calls my phone jumps to 3G but still connects and makes The call and then jumps back to 5G when call is over!
seems to be an issue in their end.
Courtcrook
Same thing happened to me and my calls only work once and awhile
Sansan
@KingofAwsome seems you are not the only one. Should you be concerned,  not sure yet. Don't know what's going on.
