Promotion (extra data won't recurring after new cycle)
Kforpeterson
hello, I would like to know if anyone have the same problem. My current plan is $25 for 1G data. (500M basic+500M because of binding credit card.) I got a 3Gb extra data for coming back. However, those 3Gb data wont renew after new cycle comes.( sorry if I dont explain that clearly). Please help.
Kforpeterson
Thanks for tge helps above.
Those kinds of features don't renew. They are added once and then you use them over time. When fully consumed they will disappear.
This applies to all Canadian add-ons.
Triguy
I think the 3GB is a bonus data which a one time offer so once you use it up then it gets depleted.
Hello @Kforpeterson ,
It sounds like the 3GB was a one time promo bonus. It should stay with you and be carried over from cycle to cycle until all used up.
Note: your PLAN data should always be used up first though, then your add-on promo will kick in (until next renewal), and so on.
