Promotion Cycle
CRA
My 2GB for 24 months promotion started on Oct 15, 2022, and now it is in the 3rd cycle, but my account shows it is in the 4th cycle. How to fix it?
7 REPLIES 7
CRA
Thank you hTideGnow for your detailed information.
hi @CRA then open  ticket with PM CS agent and they will look into it
at : https://publicmobile.ca/chatbot.
First type Contact,
from the list of , choose "Other"
@CRA @Then try reaching out to support use my bottom link (preferred choice ) in last post and talk to agent right here in the community
bottom of page last post
CRA
Hi Handdy1,
Thank you for your answer. I tried incognito mode, but my account still shows the promotion is in the 4/12 cycle. By the way, I made a mistake in my original post. The promotion is for 12 months, not 24 months.
darlicious
@CRA
This is a known glitch that customer support will have to fix for you. Contact them as above.
walker1
@CRA
You'll need to reach out to a Customer Support Agent and have them reset that promotion counter.
Use the Chatbot Simon to get a service ticket started first.
Try signing in again in incognito mode there cache issues also you can try once signe in refreshing page for current info
Refresh page.                                           ^^^
edit if you need further help don’t hesitate to reach out to agent
Getting help from agent , through automation
  • Get help with your account the easy way by starting a conversation with our virtual assistant, SIMon. It’ll take you to relevant help articles, or if it’s something more urgent, it can help you submit a ticket to our Agents. Click here to get started.
Or  get direct help from a agent right here in the community ( my preferred choice )
  • Alternatively, you can send a private message to our Agents by clicking here. You’ll need to be logged in to your Community account for the link to work
