08-31-2026 07:42 PM
08-31-2026 09:08 PM
Fine print did not Stipulate that it cannot be applied to the back to school offer. I’m guessing that’s why I worked.
08-31-2026 08:23 PM
This promo code is meant for winback customers (ie. previous PM customers). Not for new customer activations.
It seems like that it worked for you. YMMV. Public mobile may pull the code as you were not the intended target customer. I don't think that they will cancel your discount, but that is a possibility.
08-31-2026
07:53 PM
09-01-2026
12:19 AM
07:48 PM
09-01-2026
12:19 AM
Actually, I just found one and used it And it can also be applied to the back to two school promo
08-31-2026 07:44 PM - edited 08-31-2026 07:44 PM
@Donte123 wrote:Does anyone have a better promo code than 20% off per month?
Hello @Donte123
At this time, there are no promo codes. Anything out there on the internet are fake. You can however, using a referral code (which you can find on reddit) you can get $10 off your second month.
Edit: sorry, just to clarify, it's a one time $10 credit.
