4 weeks ago
45m ago
Hello everyone, please bookmark this process if your esim ever gets locked. I am very annoyed that public mobile agents never suggest this option and makes you run in circle and cause a panic.
If your esim ever gets locked and your account is still active and you have access to your account on public mobile app do this a simple fix.
1) Buy an esim from the app
2) The app delivers the esim to your phone
3) activate it and voila you have connection, text, data working. This is similar to the process if you have a new phone, you buy a new esim on your new phone through the public mobile app and activating it.
4 weeks ago
Thanks. The solution was contacting Agent for PUK code via messaging
4 weeks ago
as mentioned above:
4 weeks ago
@softech see this
4 weeks ago
Please note that CS_Agent is no longer an agent account used, and agents do not monitor the post in the Community
For your PUK error, what was the exact error message? Depends on the message, you have to ask the PUK code from different places
If the message is "SIM network unlock PIN" or "SIM ME lock code NP" or "SIM not Supported" or on an iPhone's About->Carrier Lock showing "SIM locked"
You have to ask the carrier where you got the phone from for the carrier help unlocking it.
(Sorry, for this particular issue, PM support would not be able to help)
