Problem
Kimiyakhodadadi
It says I am out of the 250mg international plan, yet I have 3G of addon data. How can I make a use out of it?
8 REPLIES 8
@CGO wrote:
buy ROAMING add-on one after one. you can't use other add-ons out of Canada.
Identical roaming add-ons can't be stacked.
CGO
@hycm53 wrote:
PM only have 1GB add-on. You run out the 250MB add-on, wait 24 hours then buy another add-on.
This isn't correct. Public Mobile does have a 250MB roaming add-on.   In addition, the 24 hour wait before purchase only applies to purchasing the same roaming add-on.
Even if you're taking about domsetic-use data add-ons, 1GB isn't the only size.
hairbag1
If you're referring to the 250MB's of 10 Day US Roaming data add-on....once that data runs out, you cannot use the 3GB of add-on data as that data will only work while you're in Canada.
Is that the data you're asking about ?
hycm53
@Kimiyakhodadadi
I am a little confused about your question.
Are you referring to your data or international calling? They are 2 different services.
AE_Collector
You mean you are out of your included data for your plan… nothing to do with “international”. Just trying to confirm you aren’t mixing up an international calling add-on with your data allotment.
Quigley
@Kimiyakhodadadi
The data add on should be available to use right away after using your regular plan data.
Login into your account using a browser in incognito or private mode and do a refresh when in your account.
You'll be able to see how much data you really have left.
