07-23-2023 07:51 PM
I just bought an oukitel c33 and it's not working when I try to make calls, after attempting to make a call it says network busy. And if somebody tries to call me the calling never get through. I already reboot my cellphone, put in airplane mode. Also I tried to put in 3G/2G only but it only shows the Roger's network not PM. I'm 4G Im able to have sms, and data but not voice.
I checked online and apparently my device is compatible with PM network. So I don't know if is anything I can do to have the service.
Thanks in advance!
07-23-2023 10:07 PM
my research shows it has the required 3G but not 4G
3G: 850 / 900 / 1900 / 2100
4G: 1, 3, 7, 8, 20, 40
and PM needs these bands;
Surprisingly the site shows nothing about band spec
07-23-2023 09:56 PM
Just Rogers
07-23-2023 08:14 PM
@joshbg - as per https://www.kimovil.com/en/frequency-checker/CA/oukitel-c33 is it accurate?
What mobile networks do you have available in this phone? If you manually select the 3G / WCDMA ONLY does voice work?
07-23-2023 08:07 PM
Your Oukitel C33 is not compatible with PM. Your phone works on 900 and 2100 MHz on 3G and 800/850/900/1800/2100 and 2600 MHz on 4G/LTE.
PM operates on 850 and 1900MHz on 3G and 700/1700 and 2100 MHz on 4G/LTE.
You need at least 2 frequencies on 3G and 4G to operate.
I hope you can return it for a refund.
07-23-2023 08:06 PM
This phone does not look like it supports 3G bands for talk. Public mobile uses 850, 1900 3G band for talk. This phone is unlikely to be supported with VoLTE service by Public mobile.
07-23-2023 08:01 PM
It has two slots, I have a sim card from another country that use Rogers network, and it works for making calls. But not with PM sim card.
07-23-2023 07:57 PM
@joshbg - do you have a Rogers sim card inside? Or, do you have 2 sim slots? Try the public mobile sim card in the other one.
