Posts are Disappearing
umnikke8
Anyone know how to fix posts disappearing on the forums? I write up a post and submit it, it appears on the thread, come back later and it's gone. This has happened several times over the past week, nothing is sticking. I've tried logging out and logging back in, but that hasn't resolved it. It seems they are tagged as spam.
@umnikke8
Not sure what exactly triggers auto spam removal. I have similar posts banned at different times
Sometimes certain key words or too many weblinks in the post. Sometimes even too long of a post will trigger the spam removal.
umnikke8
Thanks for that link, interesting info.
For some reason the system starting flagging all my posts as spam, it seems to be put back to normal now.
hi @umnikke8
they are likely here
https://productioncommunity.publicmobile.ca/t5/premod/moderationitemspage/tab/rejected
from what I understand, no one moved it but just the system auto filter feature.  Hard to say what words or things you did that triggered it
Since you can make another post here, it means you are not blocked completely, so just the contents of the post
