Post flagged as spam, no reply from report yet
G6q
I have a question about switching plans but it automatically got flagged as spam, been a couple hours and not unflagged, is that going to get addressed?
G6q
Okay will do. I am typing out numbers as words as well
@G6q according to your above reply, the choice of word could be the reason
and yes, try to avoid link
G6q
@softech wrote:
@G6q
the spam filter is automatic and nothing much support can do to release the original post
you can try to rephrase you question and repost. Avoid using many numbers in the post
Thanks, i wasn't sure if reposting would make it spam but i will give it a whirl.
The irony is the numbers are from the Public Mobile plan i am considering. I shall see if there is a link. Is posting links okay or is that going to get **bleep**ged as well?
@G6q
