3 hours ago
- last edited
2 hours ago
computergeek541
Ported a number from Bell to my Public account a couple of days ago. It works perfectly, no issues. But, id like to port it to a new Telus account activation (we get a great group rate from work with the Telus plan). As they are the same company I assume it would be ok but is there any reason I couldn’t port it again?
2 hours ago
I’ve actually had the PM account for about 4 years. Never used it, $10 a month plan. I needed to port my other number quickly and it was the easiest solution to get it done fast but I wanted to migrate to the corporate priced Telus plan anyway.
3 hours ago
Poring from PM to Telus will work without problem
3 hours ago
HI @KRog
so, you want to port out already?
yes, PM is Telus owned. So, if the number is now with PM, you can for sure port into Telus. But keep in mind, you won't get partial refund for porting out before the current cycle
