Porting problem: Rogers prepaid. Can't receive calls or texts, Will it correct itself in a few hrs?
Robyn8tor
Just wondering if this type of problem corrects itself or if I have to PM a mod?
Thanks!  My old number ported in, although the screen never showed it as finishing.  I can call out and text out on my old number (which was ported).
Thanks!
Robyn8tor
After waiting 15 more minutes, it all ended up working out.  Thank you.
sunflowershine
Thanks!
@Robyn8tor It may take up to two days to get the porting completed. You will be notified by a text message when it is done.
Alex888
@Robyn8tor It sound like a stuck port, you will need to contact a moderator. You can send them a private message here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
